Manuales y Diagramas
Codigos de transmisiones
Tema: Codigos de transmisiones (Leído 17711 veces)
10 de Febrero de 2009, 04:45:10 pm »
Bueno pues hay les dejo estos codigos para que batallen menos en conseguir una transmision stock con paso largo , ya que se de varios que se estan quebrando la cabeza , esto es solo para que sepan que corona y piñon traen , para saber que relaciones en el tren de engranes me la reservo para miguelito jejejejej .
espero les sirva de algo .
color azul son las de coronas de 31 dientes ( larga )
color blanco son las de corona de 33 dientes ( mediana )
el resto son las normales de 35 dientes .
Transmission Codes
AA 1200 4.375 from chassis No 0 981 810
AB 1300 4.375 Up to 8/70
AC 1500 4.125 Also some 1300 from 8/70
AD 1200 4.375 Limited Slip Differential (LSD)
AE 1300 4.375 Limited Slip Differential (LSD)
AF 1500 4.125 LSD up to 8/70; also some 1300 from 8/70
AG 1200 4.375 Type 147 (Fridolin)
AH 1500 4.125 IRS suspension from 8/68
AH 1600 4.125 8/69-8/72
AK 1500 3.875 Type 181 Trekker up to 8/70
AK 1600 3.875 Type 181 Trekker from 8/70
AL 1500 3.875 Type 181 with LSD to 8/70
AL 1600 3.875 Type 181 with LSD from 8/70
AM 1300 4.375 Saloon and Cabrio from 8/70
AN 1600 3.875 Karmann Ghia IRS from 8/70
AO 1600 3.875 Karmann Ghia from 8/70
AP 1300 4.375 LSD from 8/70
AQ 1600 4.125 LSD 8/70-8/72
AR 1600 3.875 K-Ghia LSD from 8/70
AS 1600 3.875 Type 1 from 8/72
AT 1600 3.875 1303S and Cabrio from 8/72
AU 1600 3.875 Ditto with LSD
BA 1300 4.375 Semi-auto from 8/68-8/70
BA 1500 4.375 Semi-auto from 8/68-8/70
BC 1300 4.375 Ditto with LSD
BC 1500 4.375 Ditto with LSD
BE 1600 4.125 Semi-auto from 8/70-8/71
BF 1600 4.125 Ditto with LSD
BG 1300 4.125 K-Ghia semi-auto from 8/70
BH 1300 4.125 Ditto with LSD
BJ 1300 4.375 Semi-auto from 8/70
BK 1300 4.375 Ditto with LSD
DA 1500 4.125 Type 3 swing-axle to 8/68*
DA 1600 4.125 Type 3 swing-axle to 8/68*
DB 1500 4.125 Ditto with LSD*
DB 1600 4.125 Ditto with LSD*
DC 1500 4.125 Type 3 with IRS from 8/68
DC 1600 4.125 Type 3 with IRS from 8/68
DD 1500 4.125 Ditto with LSD
DD 1600 4.125 Ditto with LSD
Última modificación: 10 de Febrero de 2009, 07:18:19 pm por killer bug 80
manolocardenas
Re: Codigos de transmisiones
10 de Febrero de 2009, 05:20:14 pm »
Excelente Killer , ya tengo el dato , a buscarle se ha dicho!
Gracias...
707bug
10 de Febrero de 2009, 11:35:40 pm »
buena info
11 de Febrero de 2009, 02:47:35 am »
Excelente mi Killer, thanks x el dato
Leirbag
Volkswagen 75
11 de Febrero de 2009, 09:48:31 am »
A loco !!!!
Traes todo el acordeon en la manga ...
Time to back......
Benson
11 de Febrero de 2009, 10:08:23 am »
Orale !! no pues que buen dato mi Killer, gracias por compartir.
VW 1960 Classic
VW 1972 Custom
06 de Mayo de 2009, 05:32:33 pm »
Oorale esta info no la habia visto !!!
Gracias Ruben ya la imprimi.
inklam
25 de Julio de 2012, 11:42:51 pm »
duda, la mia trae BR..... esa no la encuentro.... espero me asesoren con eso
gracias
tiopelos66
reviviendo al silver
Re:Codigos de transmisiones
11 de Octubre de 2012, 10:00:08 pm »
muy buena info tengo 6 trans en mi shop a ver cuales son saludos
